Similar Documents Scripting Components
There are two built-in pipeline stages that enable pre-processing a similar documents request before executing it in the search engine, as well as post-processing (or even generating) the similar documents results:
- Similar Documents Query Processor
- Similar Documents Results Processor
- Enables processing the similar documents request before sending it to the search engine back-end
- Usage examples:
- Block the similar documents request for some of the content by search callers
- Remove one of the metadata values from the similar documents request if that value is on a specific black list
- etc.
- Enables post-processing of the similar results returned by the search engine to either
- Generate similar documents results
- Query external services
- Usage examples:
- Post-process similar documents results metadata
- Filter results based on specific restrictions
- Query external services or data sources and inject similar additional similar documents results
- etc.
